The first theme that we are addressing in the Hub is “Testing digital twin concepts”. This was identified as a key foundational element by the DT Hub members – to help increase understanding and inform the development of strategies and projects.
It will build on the Gemini Principles and generate recommendations to feed into the National Digital Twin (NDT) “Commons” stream.
The theme is summarised as “helping DT Hub members to increase common understanding related to digital twin definitions and concepts, and then to test and refine this thinking within specific use cases and projects where there is potential to deliver significant value.”
You can find out more on the objectives, activities and selection process for the theme in the attached document.
DT Hub Theme 1 report 19 December 2019.pdf
