Laurie Reynolds Posted May 4, 2021 Share Posted May 4, 2021 As part of research I'm doing in development of a Semantic Ontology for water systems, I came across an important international group working on blockchain for climate accounting. Hyperledger is coordianted by Linux Foundation and is Disributed Ledger Technology (DLT) which has published its first Ontology for climate accounting as a general ontology relevant to all 17 SDGs. They have recognised the important nexus between carbon and water and have factored the nexus into the current design. It has members drawn from around the world and a number of active WGs. If anyone is interested, there are as always a number of ways to get more involved via https://www.hyperledger.org/ 1 Link to comment Share on other sites More sharing options...
Laurie Reynolds Posted May 4, 2021 Author Share Posted May 4, 2021 4 minutes ago, AquamatiX said: As part of research I'm doing in development of a Semantic Ontology for water systems, I came across an important international group working on blockchain for climate accounting. Hyperledger is coordianted by Linux Foundation and is Disributed Ledger Technology (DLT) which has published its first Ontology for climate accounting as a general ontology relevant to all 17 SDGs. They have recognised the important nexus between carbon and water and have factored the nexus into the current design. It has members drawn from around the world and a number of active WGs. If anyone is interested, there are as always a number of ways to get more involved via https://www.hyperledger.org/ An example was given of applying accounting principles which justified cutting down trees to encourage growth of a spagnum bog because Spagnum is apparently 200 times more effiient at carbon capture and water retention than a wooded forest covering the same ground area and faster growing. 1 Link to comment Share on other sites More sharing options...
