Neil Thompson Posted May 27, 2020 Share Posted May 27, 2020 (edited) BIM Twin What is What if Files Queries Physical Real Asset Function Time stamp Time graph Transaction Enterprise Outputs Outcomes As Designed? As Intended? (for discussion) I wanted to share some early thinking with you, and please consider this a consultation not a formal announcement of direction. Following the latency post from @DRossiter87 and some conversations with people in different markets. I have found a useful framework to separate BIM from Digital Twins. There is a caveat with the following, this is not a statement of which is better. Both BIM and Digital Twinning have key benefits. Much like a chef has a collection of knives for different use cases. The same is true for BIM and twins. BIM as defined in the standards available sets out how data can be procured in a transactional model. This is where a client can set the information requirements for a supply chain to author and deliver information for a particular purpose. The table above sets out a series of differences and I will work through them one by one to explain what they mean and how they differ. 1. What is vs What if A BIM will tell you what something is, it cannot answer the question what if. The IMF sets out a pathway for askign questions of datasets. For example “What if I turned this value off?”. 2. Files vs Queries Very similar to the above, but with a view on functionality. The BIM sets out the container of the data and the files within. These files include CSV files or a SQL databases for example. The query in the twin space is an operation on the dataset or file. 3. Physical vs Real The BIM space treats physical elements as assets. Those assets would be on some form of register which lists 'tangible things'. Those assets generally develop over time in line with the level of information need. In the twin space this representation of the physical is abstracted up into its function. The real aspect is how the object interacts with reality. This interaction is physically within the system (a pump pumping water) and is broader service / organisational purpose (the pump provides a minimum pressure to supply water to customers and is linked to the revenue stream that, for example, is charged by the cubic meter of water.) 4. Asset vs Function Related to the above, the asset focus is purely on the performance specification and range of the asset's performance in isolation. The twin considers the function the asset plays. @Simon Scott explained a great example of this. The function of a level crossing is to ensure two types ofmobile infrastrcture do not collide (please correct me if im wrong here simon), there is a difference between asking for a level crossing (an asset) and asking for two infrastructures not to collide (a function) are fundementally two differnt questions. 5. Time stamp vs time graph Time in BIM is a time stamp against a transaction or digital snapshot of an asset. The twin aspect is the time graph, the status of a person over time changes. The queries from the twin understand the historical elements of an asset. For example, when searching for an actor on google it can piece together data of that person from a series of datasets that allows a comprehensive history of that a actor to be rendered. 6. Transaction vs Enterprise The BIM standards describe a process for multiple parties to transact data. They set out how data can be procured, authored and delivered as a series of transactions. The twin represents an enterprise view where data flows with purpose aligned with agreed outcomes. 7. Outputs vs outcomes BIM through its focus on transactions and assets can only provide insight on outputs, where twins focus on functions and enterprise it can provide insights on outcomes. 8. 3D Rendition vs Abstracted BIM requires a 3D rendition of an asset as set out in the level of information need / requirements. For the digital twin, and to use @DRossiter87example of a BMS, there is no need for a full representation of the asset. All that is required is the data needed in order to execute a decision, either for a machine or human. Of course, if the what if statement includes a spatial requirement a boundary condition for the geometry is required. A non-geographic example, is that the BMS wants to know which rooms to heat for the day for a school, a key input could be the lesson plans from the teaching staff to understand occupancy of a space. On the other hand, a geographic example is if the AHU requires a filter replacement and the plantroom is tight for space. There would be a need for a physical representation of the space. I welcome the discussion and feedack! Edited August 14, 2020 by Neil Thomspon 3 1 Link to comment Share on other sites More sharing options...
Ian Gordon Posted August 14, 2020 Share Posted August 14, 2020 Good distinctions. Twins FTW! 1 Link to comment Share on other sites More sharing options...
Ian Gordon Posted August 14, 2020 Share Posted August 14, 2020 I stole a lot of this content and wrote the following: Our definition of a Digital Twin is as follows: A Digital Twin is a digital representation of a physical thing (and its operation) that one can query. This definition helps us to distinguish between the concept of a Digital Twin, and the more established practice of BIM. The key differences are: Digital Twins can and should be part of the construction phase, but the focus of their use is on the operation of existing physical assets (e.g. the 99%+ of assets that are not currently under construction). Within our organisation (and the wider industry), there is often a loss of data capability as projects move from construction to operations as operators have typically been unable to exploit BIM products. By designing our construction models as nascent Digital Twins we have the opportunity to define the data and logic required to operate an asset at the start of the lifecycle, and ensure that the models we create during construction have operational value. The emphasis on being able to query Digital Twins is important. A Digital Twin should not be a static representation of an asset, it should reflect the logic of that asset in operation. This means that Digital Twins need to expose not just the material properties of an asset (e.g. location, dimensions, materials, etc.) but also the business logic governing that asset (e.g. how we as the infrastructure owner can intervene on that asset to change how it performs). This allows Digital Twins to enable better organisational decision-making through simulation and 'what if' scenarios. In order to realise the two points above, the data schema underpinning Digital Twins is necessarily more complex, and more focused on relationships rather than properties. BIM data standards, such as COBie or Uniclass focus on the hierarchies of assets, and their properties (e.g. "span belongs to bridge and is made of steel"). Emergent Digital Twin data models (including our own Highways England Ontology) capture not just the properties of assets but how the relate to their wider environmental and operational context (e.g. "span is corroded by road salts, damaged by vehicle incursions, is maintained when the flange has 20%+ corrosion, and supports a flow of 50,000 vehicles per day travelling on the M25 (as well as a broadband internet cable) causing significant safety and KPI impact in the event of failure"). Creating these data models demands the creation and maintenance of a deep 'knowledge graph' of the organisation. 4 Link to comment Share on other sites More sharing options...
